Copper Flex In Main Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2013, 06:29 PM   #1
Rewards Points: 97
copper flex in main line
is there any code violation if there is a short (18") piece of flex copper pipe (one generally sold for connecting water heaters) in the main supply - downstream of the main shutoff but before the supply splits up to for distribution?
i had to rearrange some piping and the final connection will be lot easier with a flex rather than trying to align with multiple elbows
thanks
drgkjd is offline   Reply With Quote
Old 07-06-2013, 07:29 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 356
Only place I can use flex of any kind is at fixtures- after the shut off valves. This includes water heaters.
Some places even require hard pipe to water heaters.
Flex on main piping is frowned on
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (07-06-2013)
Old 07-06-2013, 08:30 PM   #3
Rewards Points: 97
thanks...how about pex? i can solder a pex adapter at each end and connect with pex.
i see pex in all new construction...assuming that is legal now
Old 07-06-2013, 10:02 PM   #4
Rewards Points: 12,882
That's a question for your inspector.
Would be no problem here, but that does not count.
Old 07-06-2013, 11:10 PM   #5
Rewards Points: 97
thanks
Old 07-07-2013, 04:19 AM   #6
DIY staff
Rewards Points: 7,174
Are you running a gas line? Pex is water pipe--
Old 07-08-2013, 01:25 AM   #7
Rewards Points: 97
water (cold)
Old 07-08-2013, 06:08 AM   #8
DIY staff
That changes everything---depending on the code in your area, pex could be used for all of the run ,or just a section----
Old 07-08-2013, 10:56 AM   #9
Rewards Points: 97
the new houses in my neighborhood have all (or most) pex...so i think it is legal.. the dilemma i have is that all my piping is currently copper so an 18' pex section would look odd.
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 11:45 AM
Main Line Clog Master Brian Plumbing 46 09-06-2012 09:38 PM
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 11:51 AM
Copper Flex Gas Line Corrosion DetroitEE Plumbing 8 01-25-2011 01:55 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
