Copper Flex Gas Line Corrosion - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2011, 09:37 AM   #1
Hi all,
Yesterday I noticed what appears to be some corrosion at the beginning of a flexible copper gas line that feeds my dryer. Could this be a result of interacting with the galvanized pipe that it is tapping off of? Does this look like something that should be replaced immediately? Thanks.
DetroitEE is offline   Reply With Quote
Old 01-25-2011, 09:52 AM   #2
Owner
LateralConcepts's Avatar
Yes, I would say it needs to be replaced immediately! I'm not a licensed gas installer, nor am I very knowledgeable regarding gas service. I know however it's not something to mess with if you don't know what you're doing. It appears it wasn't done properly in the first place. There are others here that can give you better advice regarding gas codes, etc.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 01-25-2011, 09:58 AM   #3
Thanks Brad. Yeah I figured it doesn't look good....hopefully there's a licensed gas installer that can give some input.
Let me add that I don't plan on trying to fix this myself...I would definitely hire a pro.
Old 01-25-2011, 11:40 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,... I'd just wipe it off, 'n See how bad it might be...
It appears to dip abit right there, so it coulda gotten wet, 'n corroded slightly...
You already have a brass valve between the iron pipe, 'n the copper tubing...
I really Doubt it's dissimilar metals corrosion...
Bondo is online now   Reply With Quote
Old 01-25-2011, 11:40 AM   #5
Owner
Yeah there are a couple here. Look up NHMaster. He's the most knowledgeable on gas service I think. He'll also appreciate that you plan to hire a licensed professional. Good luck.
Lateral
(208) 818-8241
Old 01-25-2011, 11:54 AM   #6
Owner
Bondo, correct me if I'm wrong... although brass and copper can be connected without problems of galvanic corrosion, there's still no insulating layer separating the copper and galvanized.
Lateral
(208) 818-8241
Old 01-25-2011, 12:08 PM   #7
Bondo's Avatar
Ayuh,... It's my understanding, the Brass makes the difference...
The Following User Says Thank You to Bondo For This Useful Post:
Plumber26 (01-25-2011)
Old 01-25-2011, 12:09 PM   #8
Good point about it getting wet, it is directly below some water pipes.
Old 01-25-2011, 12:55 PM   #9
HVAC / Plumbing
When I install gas lines. I spray soap on the fittings for leaks. If the soap is left on the copper It will turn it this color. Looks like the line has been wet. It should cause no problems. I see it all the time
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
DetroitEE (01-25-2011)
Flex gas line and electrical cable Xivion Electrical 2 08-14-2010 10:42 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 08:09 AM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
