Copper Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2012, 05:41 PM   #1
Rewards Points: 80
copper fittings
can copper fittings, "t's" in this caes, be too tight? I bought some and they have to be forced on or together.
Thoughts?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 12-26-2012, 06:01 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,626
Thoughts?
Ayuh,.... Usually after ya wirebrush the insides, 'n crocus the outsides, they'll slip together with flux paste as a lube...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
digitalplumber (12-26-2012)
Old 12-26-2012, 06:02 PM   #3
Some brands are just a pain in the butt to use. Try filing down the outside edges of the end of the pipe or tap on the fitting with a rubber mallet or piece of wood so you dont dent the fittings
Duddy is offline   Reply With Quote
The Following User Says Thank You to Duddy For This Useful Post:
Old 12-26-2012, 06:02 PM   #4
Rewards Points: 2,638
I expect there is an "optimal" fit of the pipe and fitting --- probably a few thousanths of an inch of clearance is optimal. I have never heard of fittings being too tight to solder --- but maybe others have --- they will chime in. However, I would sooner guess your fittings are out of round, rather than undersized.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Old 12-26-2012, 06:17 PM   #5
DIY staff
Rewards Points: 7,174
98 times out of 100 when the pipe won't fit easily into a fitting---it's the pipe.
Are you cutting it with a good quality tubing cutter with a sharp blade?
Are you 'dogging down' on the cutter,trying to cut to quickly?
Take a flat file and file the cut edge and remove the burr or mushroomed cut and see if it slips in after you clean up the cut.
The other 2% of the time--the fittings are dented or squashed a bit---
ben's plumbing (12-26-2012)
Old 12-26-2012, 06:25 PM   #6
Bondo's Avatar
Ayuh,... Good point,... What exactly is the pipe/ tubin' yer using,..??
Baseboard radiation is almost Impossible to cut, 'n keep true....
Old 12-26-2012, 06:50 PM   #7
Rewards Points: 744
Following up on Mike's comment -
I this problem recently. My cheap tubing cutter was creating a small lip. Knocking off the lip with a file helped.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
Old 12-26-2012, 07:11 PM   #8
Rewards Points: 80
See below:
Brand new Rigid.
No dont think so, its 3/4.
Will check tomorrow.
Old 12-26-2012, 07:12 PM   #9
Rewards Points: 80
Cutting 1/2 inch and 3/4 copper (thick wall one), It only did this on the last 2 cuts. Will double check them.
Old 12-26-2012, 07:16 PM   #10
DIY staff
You may have a few fittings that are ovalized--it happens---
Old 12-26-2012, 07:22 PM   #11
Household Handyman
Rewards Points: 1,408
Check the inside of the "T" fittings, and any others, for a small ridge. This happens a lot. Just ream the ridge out if this is the case.
The Following User Says Thank You to Thurman For This Useful Post:
oh'mike (12-26-2012)
Old 12-26-2012, 07:23 PM   #12
Rewards Points: 1,668
xxxxx
SeniorSitizen is offline   Reply With Quote
Old 12-26-2012, 07:37 PM   #13
Originally Posted by Fairview View Post
xxxxx
An OD de burring might help. I don't like leaving a burr in the ID either.
Apollo fittings with copper pipe Coolboy55 Plumbing 7 07-27-2012 08:51 PM
Copper to Pex and Using "Gator Bite" Fittings? jdm001 Plumbing 5 12-21-2011 10:23 AM
compression fittings on copper pipes Gabriel24 Plumbing 17 10-21-2010 10:28 AM
Problem joining copper fittings after fluxing. mikeg12 Plumbing 7 09-23-2010 12:29 PM
distance between fittings when soldering with copper Kelly Durfey Plumbing 4 06-14-2010 10:02 AM
