Copper DWV Test Cap - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2010, 10:58 AM   #1
Rewards Points: 258
Copper DWV Test Cap
I'd like to seal off one side of a 2 way drain. A standard cap is to long for my purpose. So I would like to know if I can use a DWV test cap. The drain is inch and a half. Thanks for your help.
Docfletcher is offline   Reply With Quote
Old 03-17-2010, 12:15 PM   #2
BIGRED
Rewards Points: 252
Is this two way drain a wye fitting under a sink? If so just put an internal 1 1/2" screw plug in the threads and tighten up. If it has external threads on the fitting you could put a rubber cap on it with a screw band clamp and tighten it up, but if you NEED to seal it off permanently it would be better to unsolder the entire fitting and remove it completely and just stub an 1 1/2" piece of DWV straight out of the wall and put a new compression fitting on it for your application.
Grampa Bud is offline   Reply With Quote
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
pex vs copper piping sizes dichroic Plumbing 6 07-28-2009 09:35 AM
Installing copper gutter to replace some concrete tiles whattodo Roofing/Siding 2 07-28-2009 07:28 AM
is a US penny in scrap worth more than US$0.01 ? amakarevic Off Topic 9 10-25-2008 09:11 PM
Flexible copper or Rigid Copper for solar? Piedmont HVAC 5 06-11-2008 09:47 PM
