Copper Drains - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2008, 03:50 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Copper Drains
HI
With the cost of copper, would you still put copper drains in your own home when doing a remodel.
Do you feel it is worth it to use copper drains over PVC.
Some 50 year old kitchen copper drains I recently removed, had not a spec of build up inside of them. How does PVC do over the long haul?
Jamie
jamiedolan is offline   Reply With Quote
Old 09-02-2008, 07:19 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Not worth the extra cost in my book.
PVC is just fine and it won't ever leak through with pinholes, etc. due to acidic water or whatever like coppr might do.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-02-2008, 07:42 PM   #3
Registered User
Termite's Avatar
Nothing wrong with copper, but modern PVC drain materials have made it both expensive and impractical. No way, I'd never recommend going back in with copper drains on a remodel. I can honestly say I've never seen anyone do it either!
Old 09-03-2008, 01:10 PM   #4
Besides being cost prohibitive, copper really doesn't have anything over PVC. Many times, urine will corrode copper. PVC is also quieter than copper, even though not as much as cast iron.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-04-2008, 07:00 PM   #5
DIY'er
jamiedolan's Avatar
A drain cleaning place had told me that from kitchens that they never see any grease build up in copper pipes, but in pvc and cast they do.
When we cleaned out my drains, the cast in the basement that the kitchen dumps into was quite filled up with grease and build up, but the copper had nothing in it. Now sure if this was really a result of it being copper or if the cast is just more likely to have problems.
Jamie
is a US penny in scrap worth more than US$0.01 ? amakarevic Off Topic 9 10-25-2008 10:11 PM
replacing old galvanized drains drewhart Plumbing 18 07-20-2008 01:14 PM
Flexible copper or Rigid Copper for solar? Piedmont HVAC 5 06-11-2008 10:47 PM
Flexible Copper or Rigid Copper? Piedmont Plumbing 1 06-10-2008 02:40 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 11:55 AM
