Copper Crimps Or Stainless Bands For PEX? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2013, 07:26 PM   #1
BillZ's Avatar
Copper crimps or stainless bands for PEX?
Going to go ahead and make an investment in tools. The stainless bands seem easier and more convenient but are they as reliable? Only doing small installs and repairs not whole house stuff.
Brands to look for and to run away screaming from?
BillZ is offline   Reply With Quote
Old 02-14-2013, 08:20 PM   #2
Rewards Points: 14,312
The stainless steel bands are harder to find. Any local box store or hardware store's going to have the brass ones.
Old 02-14-2013, 09:27 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 922
If this doesn't answer your questions- try the search barat the top
Which pex system?
Old 02-14-2013, 11:27 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
I guess this is more a personal choice but I personaly prefer the crimp method. The fittings and rings are reasonably priced and the tool is not THAT expensive (about 200 bucks). The expansion method looks pretty good too, I think that's probably another one worth looking into.
But go with whatever you see at the hardware store, no use in trying to go with a system where the parts will be hard to get in the future. Crimp and Expansion seem like the most popular. And of course there's always Sharkbite fittings for those quick small jobs. But it's worthwhile to buy the tools if you plan to do a lot.
Old 02-15-2013, 02:28 AM   #5
Thread killer
Rewards Points: 272
I use the expansion method and I love it, but the tools aren't cheap. If it's only a few fittings or a one time deal, I would use either crimp or cinch rings, whatever is available to you. They're both reliable, if done correctly
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 02-15-2013, 10:49 AM   #6
BillZ's Avatar
Thanks for the input.
It is occasional and I expect it to be in a variety of sizes. The supply house I use as well as HD here locally stock the stainless clamps. They are a little more pricy then the copper rings, but not by much.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 04:14 PM
Copper vs. Stainless for Hot Water Heater Element? deeze Plumbing 5 05-27-2011 09:16 AM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
