Old 04-19-2010, 11:25 PM   #1
Copper to Copper with gatorbite connectors
Do I need to use the plastic sleeve/plug that comes with the gatorbite when joining copper to copper? Also, is the permanent better than the removable when it comes to overall reliability?
cavwa is offline   Reply With Quote
Old 04-19-2010, 11:48 PM   #2
zep
Do not use the plastic sleeve as it is only used for pex pipe applications. Gatorbite permanent fittings have had issues in the past. I have not heard anything negative about their removable fittings. I have used them with no problems to date.
zep is offline   Reply With Quote
Old 04-20-2010, 01:56 PM   #3
Thank you.
Old 04-21-2010, 12:20 PM   #4
Knows everything but that
Originally Posted by cavwa View Post
Thank you.
Im not sure your application but I had great luck using Sharkbite fittings that I bought at HD. I have a straight fitting and a 90 degree fitting holding my master bath shower faucet. Theyve been there for about 6 months (not that long, I know) with no problems. Ive been told since they are accessible that they meet code as well but that very well may have been bull.
Shane
JakAHearts is offline   Reply With Quote
The Following User Says Thank You to JakAHearts For This Useful Post:
cavwa (04-21-2010)
copper flashing, galvanized nails... sharp Roofing 4 04-02-2010 07:43 PM
Copper hood - Looking for input steve1234 General Discussion 13 01-04-2010 02:34 PM
pex vs copper piping sizes dichroic Plumbing 6 07-28-2009 10:35 AM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
Flexible Copper or Rigid Copper? Piedmont Plumbing 1 06-10-2008 02:40 PM
