Copper Or Brass? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2011, 09:27 AM   #16
Rewards Points: 172
Originally Posted by Ron6519 View Post
I've used the Hansgrohe setup which looks the same. I also used the brass nipple setup, but you still need to mock up the setup. The nipple needs to be tight in the wall cavity and needs to project the correct amount through the wall. If I remember it's about 5/8-3/4" for the Hansgrohe. The instructions for the Moen should state the correct projection you need.
Ron
I will definitely mock it up first. Just wanted to make sure that is the proper way to set it up. I would assume using the drop ear elbow with a brass nipple would give me some leeway as to the width of the tile and wall...
zephed666 is offline   Reply With Quote
Old 02-09-2011, 03:50 PM   #17
Rewards Points: 172
It depends on the reach of the Moen threads. The top ell is threaded into by the shower arm which is straight and can reach into the ell for a distance. The Moen device can only reach in so far and it gets installed on top of the tiles. It needs to be screwed in enough so it doesn't leak, but enough so that the back is snug to the wall.
Use whatever set up will work. If you need to mock up a few setups, do it now. Once the pipes are soldered and the tile is up is not the time to find out there's an issue.
Ron
what is the best to use on the threads - tpae dope or teflon tape? I alos read about the best thing to use is Blue Block. Any recommendations?
thanks!
Old 02-09-2011, 09:05 PM   #18
Rewards Points: 5,336
thanks!
Teflon tape works for me. Three or 4 rotations of tape and you're good.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
zephed666 (02-10-2011)
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 09:06 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 04:03 PM
Copper or PEX (and which PEX connectors) SFX Group Plumbing 3 11-03-2010 08:06 AM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 10:29 PM
