Old 12-10-2011, 06:32 PM   #1
copper to ball valve
how do I solder in a ball valve to !/2 " copper? Won't that damage the plastic holder thing in the valve housing?
fese is offline   Reply With Quote
Old 12-10-2011, 06:38 PM   #2
you clean pipe, use fitting brush on inside of valve apply paste heat up joint apply leadfree solder.....don't over heat valve...
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
oh'mike (12-10-2011), plummen (12-10-2011)
Old 12-10-2011, 07:47 PM   #3
And have the valve in the open position when soldering. A faster way is to just use a Shark Bite ball valve. That way the two just slip together.
Old 12-11-2011, 04:46 AM   #4
thanks!
looking for an electronic ball valve with timer tominator Plumbing 1 03-24-2011 01:05 AM
Ball vs. Gate Valve BigJimmy Plumbing 10 06-02-2007 07:49 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 09:23 PM
