Copper Adapter On Frost Hydrant - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-13-2011, 04:36 PM   #1
Rewards Points: 1,062
Question
copper adapter on frost hydrant
the water comes into my shed via a 3ft frost hydrant whose tap is 3/4" threaded. i want to run copper pipe from there. was wondering if it's bad to put a female 3/4" threaded-solder adapter onto the tap and then solder from there because i am afraid that the torch heat may cook the pipe dope too much (it would certainly melt teflon tape).
i also considered soldering the pipe to the adapter first and then twisting it onto the hydrant but that's not a good option for me because the pipe needs to make some swift turns right after the hydrant (tight space) and i'd prefer soldering it while it's in place.
any thoughts ?
thanks
Old 07-13-2011, 04:47 PM   #2
DIY staff
Rewards Points: 7,174
You are right---you will cook the dope and it will leak,
Best is to solder the fitting to a stub--cool--dope and tape---install---then pack it with wet rags to keep it cool,,and pray.-
This might be a good spot to try one of those new fangled Shark Bite fittings.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
amakarevic (07-13-2011), plumber666 (07-13-2011)
Old 07-13-2011, 05:01 PM   #3
i loathe the idea of shark bite fittings. but thanks.
Old 07-13-2011, 05:55 PM   #4
i soldered with them connected for 20 years with pipe dope and teflon tape and never had a problem. i only got them as hot as i needed for the solder to flow.
The Following User Says Thank You to DannyT For This Useful Post:
Old 07-13-2011, 06:59 PM   #5
another thought i am entertaining is to use PVC instead of copper. it's a shed and it should suffice. the pipe will be exposed all the way so if it does leak at any point, it should be easy to fix (no drywall to break).
Old 07-13-2011, 07:29 PM   #6
DIY staff
I'm with you on the Shark Bites----I've bought them to try but never have.
Plastic pipe would be an excellent choice for an out building.
Old 07-13-2011, 07:37 PM   #7
Plumb or Die!
Sorry, I pushed the "Thanks" button before I saw the Sharkbite part. I used them once, but I'd rather have not.
plumber666 is offline   Reply With Quote
Old 07-13-2011, 08:27 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 348
Are you sure the bib is 3/4"? Could it be 1/2" hose thread? If so, use a FHTxFIP adapter as a union. Attach one side to the pipe of your choosing and the other side to the hose bib.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
frost hydrant installation amakarevic Plumbing 5 08-22-2010 03:34 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
galvanized steel frost hydrant amakarevic Plumbing 4 07-26-2009 09:51 AM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
