Converting A Washer Drain Into A Sink Drain - A Head-Scratcher - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2012, 09:10 PM   #1
Converting a Washer Drain into a Sink Drain - A Head-Scratcher
I have an area in my small garage/apartment where a washing machine was once located. Iíd now like to put a kitchen sink there. You can see by the diagram below that the drain is unvented. Iím sure that isnít up to code for a kitchen sink (probably not for a washer either). My question is how should I vent this? My only option seems to be to go over to the main vent stack with a vent. BTW: The bottom horizontal drain line is under a concrete slab.
Hereís what I have:
Would this be OK?
Or should I do this?
TheJazzMan is offline   Reply With Quote
Old 10-14-2012, 11:16 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 444
your first choice will work
What program did you use to draw that? I like the shadow affect
Old 10-15-2012, 08:09 AM   #3
Thanks for the reply. This drain going through the slab into the main drain line (not through the stack) had me a little confused.
I used Pixelmator (MAC) to draw the diagrams.
Washer Drain Hose ? calebm12 Plumbing 2 07-09-2012 10:43 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
Washer Drain Overflows ryanb4614 Plumbing 2 03-21-2012 12:12 AM
Condensate draining into sink drain fritzycat1 HVAC 0 01-23-2011 02:39 AM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
