-   -   Converting a Washer Drain into a Sink Drain - A Head-Scratcher (http://www.diychatroom.com/f7/converting-washer-drain-into-sink-drain-head-scratcher-160097/)
TheJazzMan 10-14-2012 08:10 PM
I have an area in my small garage/apartment where a washing machine was once located. Iíd now like to put a kitchen sink there. You can see by the diagram below that the drain is unvented. Iím sure that isnít up to code for a kitchen sink (probably not for a washer either). My question is how should I vent this? My only option seems to be to go over to the main vent stack with a vent. BTW: The bottom horizontal drain line is under a concrete slab.
Hereís what I have:
http://yorkievillage.com/images/WasherDrain.png
Would this be OK?
http://yorkievillage.com/images/prop1.png
Or should I do this?
http://yorkievillage.com/images/proposed.png
TheEplumber 10-14-2012 10:16 PM
199 Attachment(s)
your first choice will work
What program did you use to draw that? I like the shadow affect :thumbsup:
TheJazzMan 10-15-2012 07:09 AM
Thanks for the reply. This drain going through the slab into the main drain line (not through the stack) had me a little confused.
I used Pixelmator (MAC) to draw the diagrams.
