Old 08-05-2008, 05:29 AM   #1
Send a message via Yahoo to fburke
Default Converting to Propane for cooking
I am looking to do a remodel of my kitchen and would like to add a gas (propane) stove, right new I have electric. My problem is my home is on a slab so I can not run pipes underneath.
Option one relocate stove.. Is it possible / legal to run pipes into the attic and down an inside wall?
Or leave stove where it is I would have to run along the outside wall under a porch and come through an outside wall.
Would a local propane company do the piping for a discount where I will be a new customer or would I need to call a plumber? I will not mess with gas myself not that dumb.
What am looking at for a ball park cost…I’m only looking at about 30 ft of piping.
thanks !
fburke is offline   Reply With Quote
More On This Topic
Propane can be an economical way to heat your home. There are portable propane tanks you can use for grills or to heat campers. There are even vehicles powered by propane. Let's look at some ways to save money on this fuel. Read More »
Ok, so on the new oven on the new stove, the gas inlet is here. So that's where the gas is going to go in and then it goes into a regulator and then goes to the valves and to the burners. So we're going to need the fitting which will go into this, this... Read More »
Gas Stove Piping
Gas Stove Piping by Expert Village
Okay, now you can see, this is a standard gas supply; it's in a black steel pipe. Now you should always use black pipe for gas. This is a black pipe fitting here, and this is black pipe fitting, and this is brass. You should not use galvanized, you can... Read More »
Restoring an old stove is a big project. Refurbishing this appliance from scratch requires a lot of time and some expense. Learn about the internal workings of a stove and gain an understanding of the mechanics of a stove to facilitate the refurbishment. Read More »
Hi I’m Anna from annawillowglassdesign.30art.com and I am going to show you how to make an interesting shaped Christmas ornament using an optic mold. Now I am going to go over here and gather out of the furnace onto the blow pipe. I am actually... Read More »
propane heat sharpeidar HVAC 1 12-04-2007 09:17 PM
Propane heating questions Badfish740 General Discussion 1 09-25-2007 09:46 PM
Propane detector w/ automatic shutoff kamo Plumbing 2 07-06-2007 06:51 PM
Propane hot water heater philmeister Plumbing 3 04-29-2007 09:20 PM
Propane Smell sjhandy1971 HVAC 4 01-06-2007 06:54 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
