Converting An Old Brass Tub Drain To Sched 40 PVC? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-29-2014, 09:57 AM   #1
Rewards Points: 6
Converting an old brass tub drain to sched 40 PVC?
During demo of the bathroom we noticed the old brass tub drain was broken right at the point where the vertical piece meets the trap. So ideally I would like to convert it to a schedule 40 PVC setup for the new tub. Based in the photo can this be done? Would we need to cut out the old trap from behind the solder joint and couple the PVC setup to that?Converting an old brass tub drain to sched 40 PVC?-imageuploadedbydiy-chat1414591027.350637.jpg
tefuzz is offline   Reply With Quote
Old 10-29-2014, 12:58 PM   #2
Rewards Points: 12,808
Should be trying to get rid of all that old copper or bronze pipe before it starts leaking.
Old 10-29-2014, 02:59 PM   #3
Rewards Points: 1,684
Joe will cut it out for free also...
What you need after you cut it back to copper pipe is this.
http://www.supplyhouse.com/Fernco-30...FZFaMgodRG4AJA
Its a proflex model 3001-150 copper to plastic transitional coupling.
Just joking Joe...
Old 10-29-2014, 03:31 PM   #4
Rewards Points: 6
I had picked up the coupling in the photo here when I picked up the drain kit. Same thing correct? Converting an old brass tub drain to sched 40 PVC?-imageuploadedbydiy-chat1414611101.995455.jpg
Old 10-29-2014, 03:38 PM   #5
Wrong coupling that one is for cast iron to cast iron. It will not make a smooth connection and hair will get caught clogging your drain.
Old 10-29-2014, 03:45 PM   #6
Rewards Points: 6
Hmm... I grabbed that one specifically because it says "for connecting cast iron, plastic, and steel drain pipes and fittings"
Do they have the proper one at the big box stores or is this a plumbing supply house purchase?
Edit, I see now it doesn't say copper also... Yep, I'm a genius lol
Old 10-29-2014, 06:35 PM   #7
Rewards Points: 136
I am going to agree with Joe and suggest the coper drain lines be removed now that you have things open. It is a well known fact, especially on horizontal lines, that copper drains fail eventually, usually within 30 years of install. However, if you insist on taking that chance of ripping things up again 2 years from now, how about just purchasing a new brass j-bend with a captured nut and not cutting the copper at all?
karin els is offline   Reply With Quote
"custom" washer drain using rain downspout- venting question denemante Plumbing 5 02-13-2013 08:56 AM
Zep Drain Care for larger drains? Ultrarunner2017 Plumbing 13 01-10-2013 10:51 AM
How to remove brass drain flange from fiberglass shower pan scottyv81 Plumbing 21 09-23-2012 02:03 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
