Old 03-03-2012, 04:37 PM   #1
converting kitchen single sink to a double sink
How intailed is it to convert a single kitchen sink to a double sink?
amlycia is offline   Reply With Quote
Old 03-03-2012, 05:28 PM   #2
Super Moderator
Do you have plastic drain pipes in the house?
Are you installing a new counter top?
If using the existing top--what is it made of?
Old 03-03-2012, 05:30 PM   #3
A picture of what you have now would also help.
Old 03-04-2012, 01:00 AM   #4
Maryland
1. Shutoff and disconnect supply lines
2. Remove drain/trap from bottom of sink
3. Remove sink
4. Modify counter to fit/support new sink
5. Install new sink
6. Install continuous waste drain
7. Re-install trap below continous waste
(Modify drain from wall/floor as needed)
8. Reconnect supply lines
9. Turn on water at valves and test
10. Have a beer!
Pittsville is offline   Reply With Quote
Old 03-04-2012, 07:14 AM   #5
MarginallyQualified
I'm converting a double to a single.
I hate double sinks... neither one is big enough.
Come by here in about a month and I'll give you mine.
Old 03-04-2012, 07:24 AM   #6
how wide is base cabinet ????? will a double bowl even fit....
Why does my Kitchen Sink Smell? Syz Plumbing 10 10-30-2011 11:13 PM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 10:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
