Converting From Furnace To How Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2008, 10:14 AM   #1
Converting from furnace to how water heater
I have an old oil burning furnace that heats the hot water. The water does not have any tank it goes to when heated. I guess the pipes are heated. Anyway, I want to get an electric hot water heater and was wondering how to disconnect the hot water heating from the furnace.
I am hoping to eventually convert my heat to electric as well.
skittlzski is offline   Reply With Quote
Old 05-16-2008, 10:44 AM   #2
Registered User
Termite's Avatar
Can you take a picture of the current piping configuration??? That would be a big help for us to be able to assist you.
Old 05-16-2008, 11:10 AM   #3
Rewards Points: 834
No you don't have a furnace. You have a boiler. The boiler heats water inside it's core. If this boiler provides heat and how water, then you have 2 cores inside the boiler in a standard, typical oil-burner boiler arrangement.
If you want to convert to electric water heating, the potable water input to the domestic coil, and output from, is removed and re-piped to a water heater. If you want to convert to electric heat that is an entirely different animal.
Wherever you live, I hope electricity rates are lower than .04 per Kwh because if it's not, heating with oil is cheaper.
LawnGuyLandSparky is online now   Reply With Quote
New High Efficiency Gas Furnace & Hot Water Heater frank08226 HVAC 2 04-17-2008 01:06 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
