Old 05-10-2009, 04:38 PM   #1
Just call me Andrew
Converting copper to schedule 40 pvc
I have a double check valve assembly for my sprinkler system, installed by a plumber. I am planning to do all the work after the DCVA myself, in PVC. THe DVCA has a female 1" threaded copper connection on the outlet.
How do I go from that to PVC? Can I screw in a PVC adapter right into the copper (the adapter would be male 1" threaded to female 1" slip).
Thanks.
secutanudu is offline   Reply With Quote
Old 05-10-2009, 05:15 PM   #2
Using a male adapter should be fine. I have seen problems with female PVC adapters, and some areas do not allow them. They have a habit of leaking and cracking.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-10-2009, 05:35 PM   #3
Just call me Andrew
Great, thanks.
Old 05-12-2009, 11:35 AM   #4
Just call me Andrew
You mean male on the PVC adapter end, right?
Like...if situation were reversed and the DCVA had a male threaded end, you'd have me convert male to female with copper, then screw in male PVC threaded?
Old 05-12-2009, 01:21 PM   #5
YUP. PVC female adapters are easily over-tightened and crack fast. I hand tightened one and had a leak. When I removed it, crack was apparent and I did not force it by hand.
Old 05-12-2009, 03:51 PM   #6
Just call me Andrew
PVC Female to PVC male....that's ok, right?
Old 05-12-2009, 07:40 PM   #7
If both lines are PVC, they should be glued. Female PVC adapters are a problem. If you want to take the chance of a leak, use the female adapter.
Old 05-12-2009, 10:01 PM   #8
Just call me Andrew
OK, got it.
What about PVC unions. They OK? I want to put them after each of my valves so I can disconnect them and take them inside (along with the whole manifold) for the winter.
is a US penny in scrap worth more than US$0.01 ? amakarevic Off Topic 9 10-25-2008 10:11 PM
Flexible copper or Rigid Copper for solar? Piedmont HVAC 5 06-11-2008 10:47 PM
Flexible Copper or Rigid Copper? Piedmont Plumbing 1 06-10-2008 02:40 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 11:55 AM
Converting from copper to pex wease Plumbing 3 08-30-2007 08:52 PM
