Old 11-24-2012, 05:11 PM   #1
Question
Converted coal to gas steam boiler leek.
I have an old conveyed steam boiler with a leek in the jacket.
I want to use Hercules liquid sealer.
I added one quart but the leak is low and did not seal.
Can I run the boiler with extremely low water to try and seal the crack?
Should I clean the rust and slag scale off the boiler jacket prior to trying sealer again?
Should I clean epoxy and try sealer again?
Please help
Thanks Sam
Dr Sam is offline   Reply With Quote
Old 11-24-2012, 05:26 PM   #2
don't want to bring down the party...but if this is and old conversion...Its really time for a new furnace.... repairing it may not hold for long..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
joecaption (11-24-2012)
Tags
boiler leek, boiler sealer, steam
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 07:10 AM
Repairing converted Steam to Hot Water Radiator system - HELP! JonathonT HVAC 0 09-27-2011 10:08 AM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Steam heat Boiler burns, steam doesn't travel? tomhere HVAC 18 10-16-2010 04:01 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
