Convert A Shower Into A Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2010, 08:51 PM   #1
Convert a shower into a bathtub
I wonder if I could convert my shower into a bathtub. My problem is that my shower is 4.5 ft. Also the drain in my shower is located in the center.
Do you think I could find a deep bathtub with that measurements?
My budget is very small, so I need to find a bathtub for 4.5 ft. Any suggestions where to find one.
Carl
romacarl is offline   Reply With Quote
Old 02-16-2010, 09:48 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Home depot, lowes, or call a local plumber.
Journeyman Plumber
Old 03-04-2010, 06:45 PM   #3
Rewards Points: 282
Funny, I'm doing the same thing except that fortunately, I have exactly 60" wall to wall so I can use a conventional tub. here is a link to a 54" American standard on Lowes' site http://www.lowes.com/pd_89243-95384-...911_4294933768_
You will have to move that center shower drain over closer to the wall to accommodate the tub drain.
Jim F is online now   Reply With Quote
Old 03-05-2010, 02:32 AM   #4
The critical measurement is the rough in
sometimes the framers will frame a 60 inch opening and it will get framed down to match a plumbing fixture. If the rest of the room is 59" (60 inches - 2 sheets of sheetrock) then you are probably roughed in for 60 inches
You will be doing some plumbing though. You won't find a tub with the drain in the middle like a shower they are on the right or left side. The in wall plumbing will also need to be changed as well as the valve.
Youll need to remove a couple of feet of sheetrock on both sides of the shower on the bottom 4 ft to get the new tub in there. It will be like a brain teaser to get this to fit into the hole. It is a two strong person job.
I've not seen a 4.5 ft tub check around.
Five Arrows is offline   Reply With Quote
Bathtub faucet runs when shower is on aggyanna Plumbing 2 12-21-2009 09:21 AM
Convert bathtub to stand shower hoadoan Kitchen & Bath Remodeling 3 05-30-2009 11:44 PM
need to convert a bathtub into a shower q5485 Plumbing 9 11-30-2008 09:39 PM
convert bathtub to shower argos Plumbing 10 02-19-2008 11:53 PM
Replace Bathtub w/ Shower Only mahjohn Building & Construction 3 07-06-2006 08:11 AM
