Convert Oil Heat To Gas Heat - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-05-2008, 09:33 AM   #1
Convert oil heat to gas heat
Is it worth it to convert oil heat into gas heat?? If yes can someone can recommend any good contractor with their own personal experience. How much does it cost (an average)?? Do we need to change the chimney as well??
farooq is offline   Reply With Quote
Old 07-05-2008, 02:36 PM   #2
aint neither one cheep anymore but at least with oil your only paying for what you use and not for what is in the line or a sur charge I had all my Natural gas shut off and since the electric company gives a discount if you heat with electric I am swithching to that plus I get a tax credit.As for a contractor we dont know where you are so any recomendation would be worthless
clasact is offline   Reply With Quote
Old 07-05-2008, 04:47 PM   #3
Don't do it. I made that mistake 6 years ago. There are more BTU's of heat in a gallon of oil than gas. The cost to convert you will never recover. Both are not cheap as clasact stated. I would look at adding some kind of solar to help. If you do decide to do it do not buy a Trane. We had a lot of trouble after 2 years.
BillyD is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
New Thermostat- Heat comes on when on "Cool" daviar HVAC 3 06-29-2008 05:24 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 11:17 AM
