Convert Mark 89 From Aquasensor To Timed Regeneration? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2012, 12:00 PM   #1
Question
Convert Mark 89 from Aquasensor to timed regeneration?
I have a 21 year old Culligan Mark 89. Have replaced seal packs twice, aqua-sensor once. All regeneration stages, flow rates are normal, however, the Aqua-Sensor feature seems to have failed (no automatic regens- water again soft after manual regen). The unit requires pushing a red button on the timer plate before starting manual regeneration.
I'd like to alter the circuit board, and set up timed regens every 2 or 3 days, using the 6 day wheel on the timer plate. Others have reported Culligan techs doing this in the past. Does anyone know the procedure? I assume it'd be disconnecting the aquasensor, and overriding/bypassing that red button, somehow. Hard to find any circuit info online pre-1994.
Any ideas about an easy/cheap method to determine if the unit ran a regen cycle in the middle of the night or not?
Thanks in advance,
Bo
BoinLV is offline   Reply With Quote
Old 05-12-2012, 12:58 PM   #2
Water Treatment
Rewards Points: 900
Sounds like the simplest would be to find a timer assembly from either the 89 or 812 that is a 6 day clock and change them out.
I know that in the early 90's Culligan had the resin guard system that I have removed and turned them into a simple softener.
Have not done the removal of the aquasenor , but it can be done.
Having a photo of the valve and the wiring would most likely show me how that can be done.
Akpsdvan is offline   Reply With Quote
Old 05-12-2012, 06:10 PM   #3
pix, clarification
Thanks, Akpsdvan - you appear to be the go-to online guru for softeners; you've already helped me in the past!
To clarify, I have the 6 day wheel in place (black asterisk)Name:  timer-resize.jpg
Size:  88.5 KB The red button (white asterisk) must be pressed before a manual recharge can be initiated with AquaSensor in place. Generally, the metal "ears" on the day wheel are pulled out to manually set regeneration frequency, however, with AquaSensor, "all six of these must be pushed in for a recharge to actually occur," per manual. I tried doing 3/6 recharge by pulling every other ear, and no regenerations occurred (no salt use).
Here's a circuit board label: Name:  CB label-resize.jpg
Here's the red button: Name:  switch-resize.jpg
Size:  89.1 KB This is a simple momentary continuity switch (usually open).
The circuit board itself: Name:  CB comps-resize.jpg
And connector close-up: Name:  connector end-on--resize.jpg
Searching the web for the numbers on the board yields nothing. The violet/white leads from the CB connect to a spring switch behind the timer plate, the spring apparently engaging a slot in a plastic cylinder behind (connected to) the salt dial. (?)
I am wondering if I could disconnect the sensor leads (or not) and just jumper across the red button switch, then pull the timer ears, to schedule every 2 or 3 day recharges. But I hate to blindly experiment and fry the CB.
BTW, I "invented" a mickey mouse "monitor" to tell if the unit ran overnight:Name:  monitor-resize.jpg
Size:  92.8 KB - if the nut falls off, it ran!
Appreciate your thoughts/help
Bo
Old 05-12-2012, 06:47 PM   #4
Water Treatment
Rewards Points: 900
Looks to be a gutting of the wires to and from the sensor and its board... and turning the timer assembly back into the base form...
I have a timer assembly with a black plug where the red button is at.. but I have removed the wires from it... but I could go and get one out of my pile of valves that still has the wires in place to do a photo of what we should end up with when it is all done.
Check your other post for a pm.
The Following User Says Thank You to Akpsdvan For This Useful Post:
BoinLV (05-12-2012)
Old 05-13-2012, 01:17 PM   #5
Thanks, again. I located a wiring diagram online: Convert Mark 89 from Aquasensor to timed regeneration?-mark_89_wiring_diagram-75-.jpg
I assume the method may be to disconnect the 120VAC power to the aqua-sensor circuit board, but one concern is the circuit board output to the Timer Program Switch (via the orange to black wires). There are no voltages listed, and I can't find a diagram of the circuit board anywhere. Probably 120V?
Bo
Old 05-13-2012, 02:40 PM   #6
Water Treatment
Rewards Points: 900
I have gone over the wiring and removed the sensor and board and the wires for it, then tied together the black from the timer program switch to the black timer homing switch black.
Unhooking the top micro switch on the timer board.
Convert Mark 89 from Aquasensor to timed regeneration?-mark_89_wiring_without_sensor.jpg
Old 05-14-2012, 08:56 AM   #7
Thumbs up
That should do it!
Many thanks to you, and Howard!
Blessings,
Bo
Old 01-09-2015, 08:55 AM   #8
Rewards Points: 14
I know this post is 2.5 years old but THANK YOU Akpsdvan!!
Got my Mark 89 up and running again after a circuit board melt down. I know new unit are more efficient but I just can't bring myself to spending a ton of money on a new unit. I am going ride this puppy till it's last heart beat...
msjulian is offline   Reply With Quote
Old 01-09-2015, 10:47 AM   #9
Water Treatment
Rewards Points: 900
Glad to be of help.
Old 01-09-2015, 11:28 AM   #10
Rewards Points: 14
I did have a quick question. My total hardness runs right around 250. I have 2-3 people in the house. I have the salt pounds set to 6 and regen 2 times on the dial. After running a regen cycle my hardness drops to about 60 - 80. I am not sure if these numbers jive or not and I have not tested the hardness right before the system regens to see how high the hardness gets before the scheduled regen.
Do these numbers look to be in range??
Old 01-09-2015, 11:39 AM   #11
Water Treatment
Rewards Points: 900
250ppm of hardness?
That would be 15grains and after a regen your down to 4grains?
One might try every other day at the 6lbs and see how it plays out.
Could be time to replace the .6 cubic feet of resin on the mark 89.
Old 01-09-2015, 11:48 AM   #12
Rewards Points: 14
Yes 250ppm of hardness.
Just replaced the resin last winter. It has not been cycling for a while since the aqua sensor board burnt up. I removed it and bypassed the circuit as per your post above and did a manual regen this morning. What should it pull the hardness down to?
Old 01-09-2015, 11:53 AM   #13
Water Treatment
Rewards Points: 900
If your measuring the hardness in ppm then between 0 and 17.1 would be the target range your looking for.
If the system has not be working for awhile then a few extra cleanings with a larger salt dosage should be used to get the resin back in shape.
3lbs of salt to 1 gallon of water.
Old 01-09-2015, 12:03 PM   #14
Rewards Points: 14
Thanks for the help. Not sure what the 3lbs to 1 gallon of water equates to on my softener settings.
Old 01-09-2015, 12:15 PM   #15
Water Treatment
Rewards Points: 900
If you where to add about 2 gallons of water and let it set for about 2 hours and then send the unit in to a regen it would help with the resin recharging.
Pour the water down the side close to the 3inch tube with the brine float assembly.
