Convert A Bathtub/shower Combo Vavle To Shower Only? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2009, 04:26 PM   #1
convert a bathtub/shower combo vavle to shower only?
Hi,
I was wondering if someone might have some input on what i'm thining of doing.
I got a shower/bathtub combo fixture set we like for one bathroom. Our 2nd bathroom is a shower only.
I have not ben able to find a matching shower only set so i was thinking of buying the same set and sweating a down tube (about 6" and a cap) where the tub faucet usually is. effectively permanently closing off the downward flow.
The set has the diverter built into the bathtub faucet head so i'm thinking this should be okay.
Does anyone know if this is okay to do? thoughts greatly appreciated!
freewheel is offline   Reply With Quote
Old 06-24-2009, 08:16 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
shouldn't be a problem at all. After all, a tub spout diverter is effectively nothing but a stop at the end of the pipe that fills the tub, which backs up that pipe so that the water is forced out of the other end that goes to the shower head...which is the same thing you'd be doing, but on a permanent basis. Go for it!
adpanko is offline   Reply With Quote
Old 06-24-2009, 08:18 PM   #3
Remodeler
MinConst's Avatar
When you open up the wall you may even find a threaded plug can be installed to the tub end of the valve.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 06-25-2009, 11:10 AM   #4
thanks for confirming what I was thinking.
Went with sweating a tube and cap on as i trust it more than threading a pipe cap onto the valve.
Convert bathtub to stand shower hoadoan Kitchen & Bath Remodeling 3 05-30-2009 11:44 PM
Can I put a shower door on a fiberglass tub/shower combo? J187 Remodeling 3 03-08-2009 10:18 PM
need to convert a bathtub into a shower q5485 Plumbing 9 11-30-2008 09:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
convert bathtub to shower argos Plumbing 10 02-19-2008 11:53 PM
