Conventional Expantion Tank Fills Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2009, 06:22 AM   #1
Rewards Points: 79
Conventional expantion tank fills up
I have a boiler with a single zone feeding cast iron radiators. Their is a large conventional expansion tank in the ceiling (I figure 25 gallons or so). To drain it I off the valve to the tank and let it drain. It takes about an hour to get all the water out with the vacuum lock but I am positive that it is empty because I can lift if up and feel it. As soon as I turn the valve back on and run the boiler a few hours she is full again. Am I using the wrong procedure to drain the tank?
Yes I know I can replace it with a diaphram tank. I'd rather get this one working properly.
Tmb9862 is offline   Reply With Quote
Old 11-09-2009, 07:43 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
How do you know that it is full? Does the temperature/pressure relief valve on the system open to blow off excess pressure? An expansion tank will fill partially with water under normal conditions.
Old 11-09-2009, 04:41 PM   #3
Send a message via AIM to Marlin
Marlin is offline   Reply With Quote
Old 11-09-2009, 04:44 PM   #4
Rewards Points: 1,514
There might be a tiny leak near the top of the tank or in a valve at the top of the tank causing loss of the air inside.
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
Expantion Tank EdgarJ Plumbing 5 06-23-2008 09:57 AM
Toilet Tank fills slowly ronniecr Plumbing 3 09-08-2007 04:29 PM
