-   -   Conundrum: Untwisting a cast iron T (http://www.diychatroom.com/f7/conundrum-untwisting-cast-iron-t-8630/)
amakarevic 05-22-2007 10:41 PM
1 Attachment(s)
please consider the illustrated T. i can untwist the left (9-o'clock) because it is sawed off further to the left (not in pic). but how the heck do you detach the 12- and 3-o'clocks because turning either in the direction that will untwist it from this joint will be tightening it further on the other end ?
i hope i do not have to saw it.
i have always asked myself this question before i got the house and now it has escalated into an actual conundrum.
i am sure you'll have an answer ...
thankfully,
- a
send_it_all 05-22-2007 10:55 PM
I would saw through the "12:oclock" piece. Then do whatever work you need to do. Put it back together and replace the sawn 12:o clock piece with 2 nipples and a union. (it looks like there is a coupling a foot away or so). You should be able to have the nipples custom cut to length so they fit right if necessary.
Ishmael 05-23-2007 09:43 PM
Two words:
Dresser couplings:thumbsup:
