Controller Broken On Drain Cleaning Machine? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2010, 10:52 AM   #1
Rewards Points: 682
controller broken on drain cleaning machine?
I have a cobra brasscraft 1/3 hp drain cleaning machine. It has a controller that is a small rubber dome, attached by a plastic line to the motor. When you press on the rubber dome, I presume air pressure allows the motor to run.
Yesterday in the rain of course it malfunctions. The dome has sort of collapsed and I can't get any air pressure to start the motor.
I don't know if other drain cleaning machines have the same kind of starter. Is there a fix for this?
darsunt is offline   Reply With Quote
Old 02-10-2010, 11:07 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Kinda sounds like an air switch. Did you check to make sure the hose didn't blow off either the switch end or button end?
Edit : Or cracked or broken, hose, maybe a hole in it?
Journeyman Plumber
Old 02-10-2010, 04:28 PM   #3
Rewards Points: 682
Yes that's probably what its called, an air switch.
There's nothing obviously wrong, but I wouldn't be surprised if there was some damage, I have to haul the heavy thing everywhere.
Sound like I have to replace the whole thing. Damn I wanted to get it done quickly.
Old 02-10-2010, 04:33 PM   #4
Doing it myself
Alan's Avatar
can you pull the air switch off the machine and see if you blow into it if it's clicking on and off?
Journeyman Plumber
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
the dishwasher won't drain anymore (due to broken glass?) diy'er on LI Appliances 7 12-14-2009 11:38 AM
Help choosing a drain cleaning machine? darsunt Tools 2 07-30-2009 05:36 PM
Is this the proper way to handle a drain cleaning machine? darsunt Plumbing 6 07-28-2009 06:52 PM
