Control Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2012, 07:51 PM   #1
Control valve
Is it okay to just jump the two wires on the control valve and leave them tie together THIS IS ON A GAS HOT WATER HEATER THERE IS TWO WIRE COMING OUT OF IT THE OLD VALVE DIDN'T HAVE THESE
JOEG92749 is offline   Reply With Quote
Old 02-08-2012, 07:54 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Maybe a pic?
or
A little bit more info.
Such as two wire on what or what control valve. We talking faucet, furnace dryer, ice maker what control?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-08-2012, 08:18 PM   #3
Rewards Points: 582
is this a newer control valve for water heater and you have the old style...pictures...as plumber 1o1 said...
Old 02-08-2012, 08:21 PM   #4
Yes it is don't have any pics,
Old 02-08-2012, 08:22 PM   #5
Rewards Points: 560
The two wires you are talking about probably are coming off a sensor. This sensor is called an Oxygen Depletion Sensor. If the sensor is bad then replace the sensor other wise figure out what is causing the sensor to cut off the control valve.
Will the water heater lite and burners operate?
Old 02-08-2012, 08:25 PM   #6
Yes it stays lit
Old 02-08-2012, 08:25 PM   #7
Rewards Points: 582
I think those wires are for a safty switch that your old heater does not have...you could try it by installing valve and jumping wires togeother.....as long as its not a whirpool control......if it works make sure it cycles..on -off
Old 02-08-2012, 08:27 PM   #8
The old one didn't have a sensor attach
Old 02-08-2012, 08:27 PM   #9
Rewards Points: 560
What does the install instructions say to do?
Usually if there is an upgrade in valves and being used in a water heater without the need of the sensor then there should be instructions.
Did you order this valve specifict to this water heater or just get a valve?
Old 02-08-2012, 08:27 PM   #10
It is a whirlpool
Old 02-08-2012, 08:30 PM   #11
Just got one at lowes
Old 02-08-2012, 08:31 PM   #12
Rewards Points: 582
Yes it stays lit
turn up thermostat see if it starts watch it for a cycle see if it shuts off at tempture...then draw water to start see if it starts...thats a cycle..
The Following User Says Thank You to ben's plumbing For This Useful Post:
JOEG92749 (02-08-2012)
Old 02-08-2012, 08:32 PM   #13
Rewards Points: 560
THat's the first mistake.
Get one spefific to your water heater.
The Following User Says Thank You to Plumber101 For This Useful Post:
ben's plumbing (02-08-2012)
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 09:45 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
How to check gas control valve? downunder HVAC 8 02-03-2009 08:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
