Old 12-03-2012, 11:05 PM   #1
Contractor didn't pressure test shower head?
I had a contractor install my shower valve, and I just now realized he never tested the shower head after all the drywall has been put up. He said he didn't have a cap to cap the head. He told me it shouldn't be a problem since their isn't really any pressure when the water is on.
Should I be worried?
He used gator bite fixtures to attach the pipe.
vexious is offline   Reply With Quote
Old 12-03-2012, 11:13 PM   #2
I would always test the head as well. I would not be able to sleep at night if I did that to someone, but, yeah, you are probably fine. I do not use gator bites, however many people love them
paintdrying is offline   Reply With Quote
Old 12-04-2012, 12:26 AM   #3
Super Moderator
Put a nipple and a cap on it now and test it----if it is leaking you can see the water --it will run down to the mixer valve----
I would be more concerned as to why the plumber was using $5.00 Shark bite fittings instead of the more common fittings---
Old 12-04-2012, 02:01 AM   #4
She said "I had a contractor install my shower valve" I don't think it was a plumbing contractor or plumber. All the plumbers I know would test for leaks. Makes me think it was the builder.
plumberinlaw is offline   Reply With Quote
Old 12-04-2012, 05:50 AM   #5
Super Moderator
Thanks--I caught that---shark bites are seldom used by a pro---
shower pressure doubled??? codie Plumbing 4 05-13-2012 11:29 PM
is water conservation inside the shower head or the shower hose? vcreation Plumbing 1 11-11-2011 07:20 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 07:38 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 12:23 PM
