Constant Water Running But No Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2011, 01:03 AM   #1
Constant water running but no leaks
For the last 3-4 months I have been hearing what sounds like a water leak. I can hear it from every room in the house. It is very faint, my wife cannot hear it. I have turned off all the faucets, I have no sprinkler, and checked the meter. The meter showed no movement over 15 minutes and the leak detection triangle did not move.
I turned the water off at the meter and bled the lines and still heard the running water, no change, a constant running water sound. I have had three different leak detection services come ot to check on it, two of them could hear it. Two of them checked for leaks using the sthethoscope and sonar and one did a pressure check using nitrogen. The third and most recent since the other tests had already been done only did the meter check mentioned above.
No leaks were found! I turned all the power off thinking it may be an electrical problem, no difference. It has started to get louder and there is no significant increase in my water bill. I've run out of ideas, please help.
Okiewebie is offline   Reply With Quote
Old 09-07-2011, 05:38 AM   #2
Rewards Points: 272
I had a similar problem with the last house I purchased. I turned off all the water in the house and could still hear it. I then turned off my main in the house and no difference. I had the city come and turn the water off at the city main at the street. Voila the sound went away. The result was that somewhere between the city's main and my house the pipe was leaking enough that I could hear the water running inside. Ran a new line to the house end of problem. Hope this helps/
fixrite is offline   Reply With Quote
Old 09-07-2011, 05:45 PM   #3
That's strange... I have no clue what could be the problem. But it's worth checking Okiewebie's supposition.
BrendaSimons is offline   Reply With Quote
Old 09-08-2011, 08:23 AM   #4
Rewards Points: 1,216
Is your meter in the house or near the street in a meter pit??
If it's in your house did you try what fixrite was talking about ? Makes sense that the sound would transmit thru the water line into the house even if the leak was out near the source.
COLDIRON is offline   Reply With Quote
Tags
constant , leak , sound , water
I hear water running in my pipes 24 hours. Prata Plumbing 22 03-14-2012 08:08 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 08:46 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
