Constant Dripping Outside House Valve (Maybe Water Softener) - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2010, 04:49 PM   #1
Hello Professionals,
I have a small issue. I just noticed today that there is a constant drip from one of the valves outside my house. Check out the pictures below for better idea:
The pipe that is going into the house and which is at the bottom controls the house water. I am not sure what the leaking/dripping pipe does. I think it is my water softener but I am not sure. I think it has been dripping for a long time and I just noticed it today.
Also, I checked the salt tank for the water softener and noticed that there is very little water and salt inside the tank.
Need your expert advice!!
azamsharp is offline   Reply With Quote
Old 02-28-2010, 05:57 PM   #2
Licensed Master Plumber
Looks like the drip is just a loose packing stem at the ball valve. That thing is a backflow preventer and has nothing to do with your watersoftener. Do you by chance have an irrigation system?
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-28-2010, 06:00 PM   #3
Hi NHMaster,
Yes! I do have an irrigation system I totally forgot about that. I am in Houston, TX and yes couple of weeks ago we had below zero degree temperature. What are the steps to fix this problem? Whom should I call? How much will the fix cost? Can I fix it myself?
Thanks a million again!
Old 02-28-2010, 08:53 PM   #4
Do you know of any links or any videos on internet that will help me to fix this problem?
Old 02-28-2010, 10:40 PM   #5
Were the temperatures below zero or just below freezing that you experienced?
meboatermike is offline   Reply With Quote
Old 03-01-2010, 06:12 AM   #6
meboatermike It was below freezing.
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 08:08 PM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
New shower valve.. No water pressure? wilson5307 Plumbing 2 03-11-2009 10:10 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
