Constant Drip From Condensation Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2010, 03:33 PM   #1
Constant drip from condensation pipe
Should water drip constantly from my condensation pipe? It accumulates at a rate or about a quart in 15 minutes. It runs off the patio and has never dripped like this before.
tootch is offline   Reply With Quote
Old 11-15-2010, 08:22 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Condensate drips constantly when it needs to get rid of excess humidity from the system.. Sometimes it may not drip at all for a while, and sometimes it will drip constantly.
Just sounds like it's doing its job.
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-15-2010, 10:43 PM   #3
The ammount of water your AC produces is related to the ammount it removes from the air. If you've been living there in similar conditions (humidity and temperature) before and it hasn't been this bad it could indicate a number of things. It could be your air filter needs changing or your coil is dirty, both would slow your airflow and let more humidity get sucked out of the air by the AC. It could be a leaky duct or window causing your home to draw in outside air. It could also be an indication of undercharge in your unit. If your coil freezes up with proper airflow then you will know its an undercharge. If you are really concerned start checking for proper airflow and leaks.
chayce is offline   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
