Considering Tankless HWH... Reality Check Please! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2012, 08:58 AM   #31
Experienced
Jackofall1's Avatar
I would think the biggest issue with you chosen location would venting the flue gasses. A high eff unit runs on a slope horizontally and it looks like your only choice is straight vertical.
I would just replace what you have with a tankless if that is your choice where you have it now, then all you have to consider is the gas service to the unit.
The cold water sandwich is inherent to the way a tankless operates and the only way around that is a holding tank with a recirculation pump, something I am sure you don't want to get into.
Mark
Old 05-05-2012, 02:35 PM   #32
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
I did a lot of research into tankless....
What I basically concluded....the payback on gas is not there. If your doing electric...worth it...but gas? No....about the time you start to save money on gas....the unit is reaching the end of it's life. Additionally, they require more maint than a tank heater.
If the delay in getting cold water is your main concern....then consider a recirc pump.
I'll be moving my 50 gal in a couple of weeks to it's new spot which is about 15' closer to the center of action than before...but I also think I'll add a circulation system...on a timer. Only needs to circulate in the morning and evening....
Old 05-05-2012, 09:01 PM   #33
The venting can be either horizontal or vertical. The purpose of sloping the horizontal venting is to allow the condensate to drain back to the unit.
hvac benny is offline   Reply With Quote
Old 05-05-2012, 09:29 PM   #34
Thadius856's Avatar
Rewards Points: 504
Actually, placement and the piping insulation are the biggest reasons why I was considering it.
It does take several minutes to get hot water, even at the sink. None of the pipes are wrapped, so turning off the water while washing dishes means it'll be cooled a bit by the time you run it back on. And that's the shortest run at about 16 feet, IIRC. Opening up all that drywall isn't an option I'm considering right now.
But I really want that space from the tank back. I'd gladly give up the space for Point of Use units at each tap (so total 4). Do reliable point of use gas units exist that do not require venting? Electrical might be out oft reach because my service is only 100A.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Navien CR-240a tankless water heater issues PoWn3d_0704 Plumbing 20 05-07-2013 06:09 PM
Do I Need to Call in a Electrician to Check This Work? taras1 Electrical 6 12-13-2010 05:07 PM
Tankless Water Heaters zollander10 General DIY Discussions 4 07-27-2008 05:10 PM
tankless WH questions homer12 HVAC 1 02-28-2008 09:36 AM
Recommend Tankless Heater? DIYtestdummy Appliances 10 02-11-2008 08:26 AM
