Considering Tankless HWH... Reality Check Please! - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2012, 09:01 PM   #16
Thadius856's Avatar
Rewards Points: 504
I have. Doesn't seem any worse than the solid minute or two of cold water I get presently.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 04-12-2012, 09:03 PM   #17
Originally Posted by Thadius856 View Post
I called the utility company about this and they said that they have no information on what size line I have coming in. However, they did tell me that my meter is the "small" size they offer, which is capped at approximately 42,000 BTU. I haven't climbed the roof to check on the BTU rating for the central heat, but I'm not hopeful that I could get it all on this meter.
They said that they could *probably* upgrade my meter size *maybe for free*, but the lady on the phone was really unsure. She said she'd have to assign the case to a worker to come blah blah... something... blah. Either way, I'm less than 1,000 ft from a major gas pipeline. She said that *usually* service upgrades are done for free, but couldn't tell me what the largest gas line I could get here was either.
Better talk to a planner from the utility company as it doesn't sound like the person you talked to has much of a clue, or maybe you just didn't understand them. 42 MBTUH is ridiculously low for any gas meter, your central heat, if gas, is probably 60-80 MBTUH. The "major gas pipeline" that you live by is probably a transmission line and has no affect on the service to your house. You'll have a distribution line running in front of your house, or possibly behind it in the alley if you have one.
hvac benny is offline   Reply With Quote
Old 04-12-2012, 09:03 PM   #18
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Really?
So. . . someone takes a shower before you, heats the water in the line. You go to take a shower : "Oh cool the water is already warm"
*gets in shower*
"YOOOWWWW THAT'S COLD"!!!!!!
*shakes head* "What the? It's warm again?"
That would tick me right off.
Journeyman Plumber
Old 04-12-2012, 09:06 PM   #19
Thadius856's Avatar
Rewards Points: 504
My mistake. She said 420k.
I remember thinking to myself a 150k heater wasn't that big of a deal unless the HVAC was over 200k. Checking the stickers on the HVAC and dryer are on my to-do list now for sure.
Old 04-12-2012, 09:11 PM   #20
Thadius856's Avatar
Rewards Points: 504
Originally Posted by Alan View Post
Really?
*gets in shower*
Considering that the HWH and the shower would be within a foot or two of each other on opposite sides of the wall, I can't imagine it being a very big sandwich.
Old 04-12-2012, 09:14 PM   #21
Hmmm. Greek to me. Lady on the phone said something about .25psi, I think. Does that mean anything intelligible?
Yes. It means you have 7" water column service. You probably have a 200 series meter, which is good for 200,000 btu's (200 MBTUH). I work for a gas utility company north of you, but I believe our systems are similar (although we take much, much better care of ours). I'm all for DIY, even when it comes to gas. But, do you research first and ask questions, even if you think you know the answers.
Old 04-12-2012, 09:20 PM   #22
Thadius856's Avatar
Rewards Points: 504
Hmmm. It's stamped "275 CFH" and "CL-250" and "5 PSI" on the plate. But I have no idea if that's accurate or not.
Google search reveals a table that seems to indicate I'd need to know the piping length to get any useful information from it.
Old 04-12-2012, 09:20 PM   #23
Doing it myself
Alan's Avatar
It doesn't matter how close they are. What makes the difference is the time delay on the flow sensor.
How long does it have to sense water flow before it starts the sequence of igniting the burner. 4 seconds? 5 seconds? That doesn't seem like much, until it's blasting you in the back when you thought it was warm.
Not trying to talk you out of it, but you asked for a reality check.
Journeyman Plumber
Old 04-12-2012, 09:25 PM   #24
CL-250 is the model
275 CFH is 275 cubic feet (of gas) per hour
5 psi is the maximum operating pressure. (it probably has MAOP after 5psi)
Can you post a pic of you meter? If its a CL-250, I'm not sure it will supply 400+ MBTUH, unless it's 2 psig.
Old 04-12-2012, 10:19 PM   #25
Thadius856's Avatar
Rewards Points: 504
CL-250 is the model
I'll get back to you in the morning on that one.
Old 04-15-2012, 05:43 PM   #26
Thadius856's Avatar
Rewards Points: 504
Benny, sorry I didn't get back to you sooner. It's been a crazy last couple of days. Hopefully these photos show you what you needed to see.
In case you need to zoom in on the dials: http://i.imgur.com/quAVK.jpg
Edit: Odd, imgur links died. Fixing those now.
Old 04-24-2012, 09:28 PM   #27
Thadius856's Avatar
Rewards Points: 504
Bumping. Just got the yearly water quality report from the water district (still waiting on temperature). Water looks rather hard. Will I need a filtration and/or softening unit to use a tankless under these conditions?
Thanks in advance guys. Always a huge help!
Old 05-03-2012, 10:13 PM   #28
Thread killer
Rewards Points: 272
In case you were still thinking about it.
The rest of the reality check.
http://www.greenbuildingadvisor.com/...m_medium=email
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 05-04-2012, 06:27 PM   #29
Thadius856's Avatar
Rewards Points: 504
Still interested. Definitely.
Part of these studies that make it difficult for me to get real-world numbers is that they all assume professional installation costs. I know time is money, but it isn't always worth $100/hr or even $50/hr. That makes it difficult to figure out what a self-installed payback period would be.
Thanks for that study. :D Great article!
Old 05-05-2012, 08:12 AM   #30
Thread killer
Rewards Points: 272
I saw it and thought of your thread. If I'm understanding the article, there are reasons to justify buying one, just not from an efficiency stand point. Not a big enough improvement to expect much of a payback from it.
Navien CR-240a tankless water heater issues PoWn3d_0704 Plumbing 20 05-07-2013 06:09 PM
Do I Need to Call in a Electrician to Check This Work? taras1 Electrical 6 12-13-2010 05:07 PM
Tankless Water Heaters zollander10 General DIY Discussions 4 07-27-2008 05:10 PM
tankless WH questions homer12 HVAC 1 02-28-2008 09:36 AM
Recommend Tankless Heater? DIYtestdummy Appliances 10 02-11-2008 08:26 AM
