Connections PVC To Chrome - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2012, 04:45 PM   #1
Connections PVC to chrome
Hello -
First post! I am redoing my entire bathroom and I am on the final plumbing project. Hooking up my Sink. Here is what I have. My drain line is 1 1/2" PVC and I would like to connect it to 1 1/4 " chrome S-trap. Not quite sure how this is done? Do I have to use a rubber fitting or is there a pvc connector that will accept the standard 1 1/4 " chrome piping?
Hope this makes sense.
Thanks in advance.
DAVE
Also I promise to post completion photos - you have never seen a sink like this.
calderdoran is offline   Reply With Quote
Old 07-31-2012, 05:14 PM   #2
Rewards Points: 582
Originally Posted by calderdoran View Post
Hello -
Thanks in advance.
DAVE
you use 1 1/2 x 1 1/4 desanko fitting glue it on 1 1/2 pipe...or 1 1/2 desanko fitting with a 1 1/4 reducer washer...
Old 07-31-2012, 05:16 PM   #3
Rewards Points: 12,802
Chrome and PVC drains all take the same sized fittings, the chrome just cost more.
Any Lowes, HD or Menards all have the whole trap and drain all in one package.
Old 07-31-2012, 05:24 PM   #4
Glue a metal fitting onto PVC?
So I saw the fitting online - Do I glue a metal fitting onto PVC?
Thanks.
DAVE
Old 07-31-2012, 06:28 PM   #5
Rewards Points: 582
Thanks.
DAVE
no it glued on the 1 1/2 pvc..on the other end it a slip nut and washer slides over the 1/1/4 crome then tightens into the pvc...can always take it apart for service....sorry can't post pictures...still learning...ben
Old 08-01-2012, 08:30 AM   #6
http://www.bing.com/images/search?q=...FAEF91&first=1
An adapter like this will get you from the PVC to the chrome.
Old 08-01-2012, 01:46 PM   #7
Rewards Points: 582
yep thanks joe for the back-up to help op...ben sr
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 03:51 PM
pex connections Arky217 Plumbing 3 02-29-2012 12:54 AM
Connect Chrome P-Trap to PVC Drain simonua Plumbing 3 09-15-2011 02:29 PM
Asko Dishwasher Dispenser came with Different Connections momfxit Electrical 0 09-16-2010 06:33 PM
Chrome paint on plastic Thurman Painting 3 08-24-2010 01:17 PM
