Connection Of Water Intake Pipes To Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2013, 09:00 PM   #1
Connection of Water Intake Pipes to Shower Valve
I am installing a Moen 3570 valve (http://www.moen.com/m-pact/moentrol-...ONSUMER%3A3570) in a bathroom.
The existing hot / cold 1/2" copper pipes are running vertically out of the floor, only around 7" apart. That means that if I use 2 90degree FTG Elbows (http://www.homedepot.com/p/Mueller-S...52H/100348183), I will be barely able to fit the valve in, without any modifications.
The documentation for 3570 is silent on whether this is allowed. However, other documentations on the Moen's site suggest the water pipes coming out of the floor should be running parallel, 12"-18" apart. So, both the hot and cold pipes would need a 3"-5" horizontal pipe (from a 90degree elbow) before entering the valve.
I hope this is clear. Naturally, I would prefer the easier solution, if it does not cause noise / pressure / other problems.
Any insight on this project would be appreciated.
KevinAndrews is offline   Reply With Quote
Old 05-16-2013, 09:11 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 550
Offset your vertical supply risers with 45's to get whatever spread you desire for your valve rough in.
Ream the pipe after cutting to cut down on turbulance
Old 05-17-2013, 04:05 PM   #3
Thank you. I actually have enough clearance to connect a pair of street 90 degree elbows to the valve and do not "need" to get more distance. The question really is whether I "should" do it (i.e. any benefit to it)?! If I get more distance between the risers and the valves, then I need a small hortizontal pipe between the 90 elbow and the valve intake.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 06:21 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
