Originally Posted by mlitcher
Yeah, it doesn't appear to be soldered at all. I looked up Ford meter sets, and the top half of my connection looks just like the right side of the attached image.
So, that isn't something I can just disconnect and slide in the new pipe?
I wouldn't. It is a compression style fitting, not designed to be disassembled and reused. Contact your water company. They should have them on the service truck and can change it out in a matter of minutes.
Are you replacing with copper? Differentent fitting for different pipe OD's
