Connecting Water Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2010, 10:17 AM   #1
connecting water lines
How do i connect a water line coming from the water meter to that is cast iron pipe to pvc that is going to the house?
kevin68 is offline   Reply With Quote
Old 10-08-2010, 10:24 AM   #2
Rewards Points: 150
Pvc?????
If you are refering to using the PVC underground.... Then I recommend checking your Local codes. I would recommend spending the Extra money and using Copper or Poly and use Ford Couplings for your connections
Docwhitley is offline   Reply With Quote
The Following User Says Thank You to Docwhitley For This Useful Post:
kevin68 (10-08-2010)
Old 10-08-2010, 02:15 PM   #3
Rewards Points: 156
Measure your cast iron pipe. Measure your PVC. Take those measurements to your local BigBox retailer and tell them you need hardware to make them connect.
I would agree with Doc that you should use poly or copper underground. I prefer poly. Copper is somewhat susceptible to acidic soils. (but probably not in your lifetime. )
moondawg is offline   Reply With Quote
Old 10-08-2010, 03:24 PM   #4
Rewards Points: 150
I prefer Poly also... Alot easier to work with... I hate unrolling Soft Copper to fit it in the hole and trying not to have a crease. I Personally think water rushing by a crease will eventually cause a weak spot in the pipe.
Old 10-10-2010, 08:05 AM   #5
Rewards Points: 1,440
It is actually as simple as connecting to like kind namely cast iron to cast iron or poly' to poly'. You can get a nipple with screw threads to glue onto the end of the poly' pipe.
You will have to measure carefully so everything fits together exactly right without stretching when you screw the final joint together.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water supply lines - Does this look OK chrisinmontreal Plumbing 0 07-25-2010 01:27 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Insulating Hot Water Lines jeepwillies Plumbing 1 11-21-2006 03:41 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
