Old 09-04-2007, 04:50 PM   #1
Connecting Water For Frig.
We Recently Replaced Faucets In Our Kitchen, Problem Is How Do U Reconnect The Water To The Frig. There Is Tubing There But What Do We Use To Connect To Cold Water Pipe.
lulubam is offline   Reply With Quote
Old 09-09-2007, 08:38 PM   #2
Not knowing what the previous install used. I will give the two most common suggestions. You can use a saddle valve or plump in a tee from your kitchen faucet line for the supply.
Here is a link about and how to use saddle valves
http://www.naturalhandyman.com/iip/infxtra/infsad.html
Mgmopar
MgMopar is offline   Reply With Quote
