Old 01-17-2011, 02:56 AM   #1
Maryland
Connecting Water Filter Housing to CPVC
So I'm looking to connect an Aquapure AP102T whole house water filter to my 3/4" CPVC line. The filter housing is plastic with 3/4" female threads on the inlet/outlet ports. My question involves the fittings used to make the connection. (See attached MSPAINT diagram)
My goal is to have the ability to remove the filter housing from the system without cutting the CPVC. It's been suggested to me that in almost every case, brass unions are superior to their CPVC counterparts. Can I use a brass transition union (as illustrated) to make the connection to the PLASTIC housing? Taking into account that this is a cold line, are there any consequences to this approach? Metal threads mating with plastic threads? I'd rather not be stuck using CPVC male adapters and then having to cut the line if a repair/replacement of the filter housing is needed. I really want a union there for easy disassembly! Comments or suggestions?
Also, what method do you suggest for sealing the threads? Telfon tape or pipe dope? I started using Oatey Great White pipe joint compound about two weeks ago and I don't want to put the stuff down! It's approved for most metal types and PVC/CPVC pipe, so I don't really see the need to use telfon tape anymore... Am I wrong?
Pittsville is offline   Reply With Quote
Old 01-19-2011, 02:01 AM   #2
Maryland
Thoughts anyone?
Old 01-19-2011, 09:17 AM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,...Brass or plastic Unions are just Fine...
The pipe dope you've got will also work in this application...
Old 01-19-2011, 10:50 AM   #4
Owner
LateralConcepts's Avatar
Hopefully we won't see you on that new TLC show... "My Strange Addiction"
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 01-19-2011, 09:04 PM   #5
pipe dope is fine teflon tape is fine too use both if you think it might drip, usually people use brass unions for what you're doing I like sharkbite adapters and a removal tool, if you have an inch of lateral movement and you should with cpvc
plumber jon is offline   Reply With Quote
Old 01-20-2011, 02:27 PM   #6
Maryland
So, no concern with joining the metal threads of the brass union to the plastic threads of the filter housing? It won't try splitting or cross-threading, etc?
Old 01-20-2011, 02:59 PM   #7
Last week I installed a whirlpool filter on my water supply. I have a well and I've notice sediment build up. The whirlpool has a built in shut off valve on top of it. Really it's a bypass for changing the filter. I bought the filter at Lowe's for $40 works great.
mfv03ultra is offline   Reply With Quote
Old 01-20-2011, 03:01 PM   #8
i've been dealing with this problem on a job for a week or two. plastic housing and bushings with a brass pex adapter. it split the plastic bushing twice now (luckily not the housing) even though they were basically hand tight. I'm going back tomorrow to install sch 80 PVC close nipple and a brass female adapter cause i'm tired of it . so all i can say is be careful and don't over tighten if you do it
the_man is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 05:56 PM
