-   -   Connecting Water Filter Housing to CPVC (http://www.diychatroom.com/f7/connecting-water-filter-housing-cpvc-92568/)
Pittsville 01-17-2011 01:56 AM
1 Attachment(s)
So I'm looking to connect an Aquapure AP102T whole house water filter to my 3/4" CPVC line. The filter housing is plastic with 3/4" female threads on the inlet/outlet ports. My question involves the fittings used to make the connection. (See attached MSPAINT diagram)
Attachment 28796
My goal is to have the ability to remove the filter housing from the system without cutting the CPVC. It's been suggested to me that in almost every case, brass unions are superior to their CPVC counterparts. Can I use a brass transition union (as illustrated) to make the connection to the PLASTIC housing? Taking into account that this is a cold line, are there any consequences to this approach? Metal threads mating with plastic threads? I'd rather not be stuck using CPVC male adapters and then having to cut the line if a repair/replacement of the filter housing is needed. I really want a union there for easy disassembly! Comments or suggestions?
Also, what method do you suggest for sealing the threads? Telfon tape or pipe dope? I started using Oatey Great White pipe joint compound about two weeks ago and I don't want to put the stuff down! It's approved for most metal types and PVC/CPVC pipe, so I don't really see the need to use telfon tape anymore... Am I wrong?
Pittsville 01-19-2011 01:01 AM
Thoughts anyone?
Bondo 01-19-2011 08:17 AM
Ayuh,...Brass or plastic Unions are just Fine...
The pipe dope you've got will also work in this application...
LateralConcepts 01-19-2011 09:50 AM
Hopefully we won't see you on that new TLC show... "My Strange Addiction" :laughing:
plumber jon 01-19-2011 08:04 PM
pipe dope is fine teflon tape is fine too use both if you think it might drip, usually people use brass unions for what you're doing I like sharkbite adapters and a removal tool, if you have an inch of lateral movement and you should with cpvc
Pittsville 01-20-2011 01:27 PM
So, no concern with joining the metal threads of the brass union to the plastic threads of the filter housing? It won't try splitting or cross-threading, etc?
mfv03ultra 01-20-2011 01:59 PM
Last week I installed a whirlpool filter on my water supply. I have a well and I've notice sediment build up. The whirlpool has a built in shut off valve on top of it. Really it's a bypass for changing the filter. I bought the filter at Lowe's for $40 works great.
the_man 01-20-2011 02:01 PM
i've been dealing with this problem on a job for a week or two. plastic housing and bushings with a brass pex adapter. it split the plastic bushing twice now (luckily not the housing) even though they were basically hand tight. I'm going back tomorrow to install sch 80 PVC close nipple and a brass female adapter cause i'm tired of it :laughing:. so all i can say is be careful and don't over tighten if you do it
