Old 10-23-2012, 08:30 PM   #16
Connecting two pieces of 1/4" copper coil tubing
1/4" compression fitting is all you need ...as mentioned cut both ends apply alittle pipe dope on threads hand tighten nuts then 1 1/2 turns with wrench...check for leaks ...snug up a little at a time if needed.....remember its only 1/4" soft tubing.....ben sr
Mother in law coil cleaning digitalplumber HVAC 8 08-13-2012 07:31 PM
AC - Coil leaking fcabanski HVAC 7 07-04-2012 10:50 PM
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 04:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
