Old 05-05-2008, 04:15 PM   #1
Question
Connecting threaded pipes on pool fittings
I have a great deal of trouble screwing on the pipe fitting (2" pipe) that connects my swimming pool filter to the pool heater. The pipes are composition and are to be hand tightened. Although the threads look good and have been cleaned, I need to use a large wrench to tighten the coupling with a great deal of effort. What must I do/need to make this coupling smooth and easy, before I strip the threads or break a pipe? Thanks for your help!
NJ guy is offline   Reply With Quote
Old 05-05-2008, 09:21 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Apply some Teflon pipe dope.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Swimming Pool Converted To Fish Pond ghall79 General Discussion 6 05-23-2008 12:11 PM
