Connecting Sink Drain Pipe To Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2013, 02:15 PM   #1
Rewards Points: 27
Connecting Sink Drain Pipe to wall
I am working out the details on how to connect my new drain+p trap assembly to the (waste? drain?) pipe in the wall. The new stuff I have is 1 1/4" diameter PVC, and I have an 1/8" turn on the wall pipe (See pic).
From what I've read so far, I need a Fernco fitting to connect these two. The only problem I'm having now is figuring out the diameter of the wall pipe and determining if there is a fernco fitting that will work for me. I measured the outside circumference of the pipe at 5 3/4", which (using math) should come out to be a 1.91" diameter. So.. that's not super helpful. Would this be 2" and my math is failing me? Or is it metric (doubtful, house from the 60s).
Any thoughts on this? Or do I have to take off the current P trap (soldered on) and measure the pipe?
GerardW is offline   Reply With Quote
Old 03-28-2013, 02:32 PM   #2
47_47's Avatar
Rewards Points: 44
1.900" is the outside diameter of 1" schedule pipe.
47_47 is offline   Reply With Quote
Old 03-28-2013, 02:54 PM   #3
Rewards Points: 1,770
Looks like a soldered fitting. Unsolder it and install this.
http://www.grainger.com/Grainger/MUE...-Adapter-5UGA9
Ghostmaker is online now   Reply With Quote
Bathroom sink drain pipe on the side of the wall amandanory Plumbing 7 11-17-2012 11:27 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
drain stand pipe adding sink myers77 Plumbing 7 04-14-2011 10:02 PM
perforated wall drain pipe amakarevic Building & Construction 3 11-01-2010 07:56 PM
