Connecting PVC Sprinkler Pipe To Copper House Main Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2013, 05:34 PM   #1
Rewards Points: 41
Question
Connecting PVC Sprinkler Pipe to Copper House Main Line
Below you will find a picture of my current PVC lawn sprinkler feed connection to the copper house main.
The PVC connects to the copper with a threaded male PVC connector (lower left side of photo). The PVC pipe goes underground where it reverses direction and goes to the right - where you see the PVC valve. In the past I've had issues with cracks/leaks at the PVC to Copper fitting and with leaks in the PVC shut off valve (that's the current Issue I'm working on - note the pool of water below the valve).
I'd like to get some recommendations on a better solution.
A few question I have are:
1. Would replacing most of the PVC seen here with copper or brass pipe be more durable and less likely to leak?
2. Can a brass ball-valve shut-off valve be installed above ground instead of the PVC valve shown below-grade?
3. What is the best way to make the Copper to PVC connection? Is there a copper-to-PVC union I can use? The PVC threaded male adapter has been problematic.
Note: I live in southern California so freeze/thaw isn't an issue here.
Note: I added annotations to the image.
fritzycat1 is offline   Reply With Quote
Old 05-14-2013, 06:01 PM   #2
Rewards Points: 1,878
You need a backflow on that mess...
2. Your suppose to blow out the sprinkler lines over the winter.
Backflow may save your families life...
Have a good day.
Ghostmaker is online now   Reply With Quote
Old 05-14-2013, 06:54 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 994
Try sch 80 pvc
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-14-2013, 10:45 PM   #4
Rewards Points: 41
Thanks for the replies.
Ghostmaker:
* The sprinkler valves have backflow prevention built-in. Do I still need backflow between the main supply and those valves?
* It never freezes here (SoCal) - is there still a need to blow out the sprinkler lines? I occasionally use my sprinklers during the winter months - it was particularly dry this year.
* Why would backflow save my families life? What is the danger?
Javiles:
* Is schedule 80 PVC ok for above-ground installations?
* Will would you do a SCH 80 PVC shutoff valve too? or put in a brass ball-valve and then go SCH80 PVC downstream of that?
* What would you use to connect copper to the SCH80? A union, or a threaded SCH80 pipe?
Old 05-15-2013, 06:27 AM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 994
Sch 80 above below OK use a brass ball valve, what you want on that line is a vacuum breaker, I think what ghost means is these back flow devises keep out cross contamination people have gotten sick from dirty water mixing in with their drinking water. yes it dose happen more often then you might think. you also need to make sure the pipe is 100% secure and will not move, shake, vibrate, etc, if it does you will always have problems with threaded connections.
Old 05-15-2013, 07:26 AM   #6
Rewards Points: 89
What you need is one of these,
http://www.febcoonline.com/Products/765
Have the copper go in through the bottom and the PVC out the side. Must be mounted 10" higher than the highest sprinkler.
tjfslaughter is offline   Reply With Quote
Old 05-15-2013, 03:25 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
It doesn't seem right that the sprinkler take off is ahead of the pressure reducer and the main valve for the house. I am surprised that there is no back-flow preventer right at the water source. Around here the back-flow preventer must be immediately after the shut off.
Copper Pipe vs Copper Coil Tubing For Refrigerator Water Line kaalapurushha Plumbing 3 10-15-2012 08:59 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Two toilets in house not filling all the way- main line problem? mickapoo Plumbing 6 03-14-2010 09:35 PM
