Closed Thread
Old 07-19-2007, 11:36 AM   #16
Connecting PVC to Galv Pipe fitting for Drain
Thanks!
That is what I was planning on...using the smaller ell for the vent, and I got the longer sweeping ell for the drain.
Some people seem to highly promote a 2" line, but the previous was a 1 1/2" that had tons of rust inside of it, so I would think a new 1 1/2" with 2 cleanouts would do ok.
I just can't replace the entire section, and I can't imagine that it would be ok to have some parts 2" and then decrease to 1 1/2"
froddan is offline
Old 07-19-2007, 11:39 AM   #17
Sorry about the confusion, but these 90 and 45* bends are underneath the subfloor and not visible in the picture.
It is the drain that comes from the tub-shower and then connects with this sink drain.
froddan is offline
Old 07-19-2007, 12:08 PM   #18
RippySkippy's Avatar
sounds like you have a good handle on things...congrats!
RippySkippy is offline
Old 02-28-2010, 04:13 PM   #19
Wink
Which ever solution you chose, removing the threaded galvanized pipe should not be a problem.
Cut the galvanized pipe within 3/4" from where the threads start. Using a chisel, cave in the pipe just above the fitting, then the end of the pipe will easily un-thread from fitting using channel locks (water pump pliars). Using this method will leave the threads of the fitting intact and surrounding pipe will not be broken, damaged or moved.
btw, this is similar to removing a brass plug from cast iron hub (i.e. cleanout). Cut, drill or chisel out the inside of the brass plug, then cave in the plug just as it enters cat iron fitting.
I hope this helps.
Superace is offline
Old 02-28-2010, 04:33 PM   #20
Xtreme DIY'r
Thread is 2.5 years old
Scuba_Dave is offline
Closed Thread
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 07:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
