Connecting PVC Drain To A Copper Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2009, 11:36 AM   #1
connecting PVC drain to a copper pipe?
Hi,
Way back when, somebody put copper all through-out my house. Not just for water supply, but also for the drains. How do I connect a 3" PVC drain to a 3" copper drain? Are those flexible rubber/steel band couplers legit and meeting code?
Thanks in advance!
red86yota is offline   Reply With Quote
Old 02-24-2009, 11:49 AM   #2
yes they make a size for this it would be 3" copper to 3" pvc they are called mission bands
plumbbum0203 is offline   Reply With Quote
Old 02-24-2009, 11:59 AM   #3
thanks, and a twp plumbing inspector shouldn't have any problem with that connection? it's not going to be buried in a wall or anything, just in a wide open un-finished basement.
thanks!
Old 02-24-2009, 12:11 PM   #4
No-hub (also called Mission) and Fernco are two manufacturers of couplings such as you need. Be sure to tell the sales person what materials you are joining. Fernco is code compliant above ground, and No-hub is used on both above and below ground applications.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-24-2009, 09:43 PM   #5
Rewards Points: 150
3" copper! Tear it out for scrap and build a new house!
Gary
Gary_602z is offline   Reply With Quote
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 03:33 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
