Old 08-21-2008, 11:00 AM   #1
A "Handy Husband"
rjniles's Avatar
Connecting PEX to a water heater?
Can PEX be connected directly to a water heater or should use a flex connector or a short length of copper be used first. I have seen it done both ways but wonder if there is a code issue or manufacturers recommendation.
rjniles is offline   Reply With Quote
Old 08-21-2008, 11:15 AM   #2
Moderator
Termite's Avatar
The plastic pipe and fittings association PEX installation guidelines recommend an 18" minimum length of copper or other approved pipe above the water heater. Individual PEX manufacturers may have more or less restrictive proprietary requirements. I have never seen a PEX line directly connected at the top of a water heater...There's always a section of pipe. Additionally, the 12" clearance requirement for PEX from sources of heat would put a PEX-only installation in conflict with the water heater vent.
Old 08-21-2008, 11:44 AM   #3
RippySkippy's Avatar
There are at least a few options; straight (use the 18" version) , and off-set and flexible. KC is right...check with your PEX Mfr to get their recommendations.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
