Connecting New Plumbing Into Existing Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2008, 10:26 PM   #1
Connecting new plumbing into existing plumbing
I am finishing basement and have finished the rough-in for the new plumbing. Now i need to connect to existing house plumbing. I have located an accessible location to tee in my 3/4 hot and cold water lines into the 3/4 exisiting lines. But I am having second thoughts before I cut into the existing lines since I cannot determine whether I will have enough play in the existing lines to push aside to get my 3/4 tee in place. I would have to remove a large part of the ceiling to see if I have any play. Any suggestions??
Just do it guy is offline   Reply With Quote
Old 02-18-2008, 10:28 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
How much pipe is there to work with?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-18-2008, 10:36 PM   #3
Send a message via AIM to Marlin
Cut it. If you absolutely can not squeeze the tee in use slip couplings. Just have them handy before you shut your water down on a Sunday night.
Marlin is offline   Reply With Quote
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
Bathroom Tiling - On top of existing tiles??? moggiex Painting 8 12-13-2006 06:17 AM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
