Connecting New 1 1/4 Inch PVC Trap To Old 1/1/2 Inch Metal Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2011, 03:16 PM   #1
Connecting new 1 1/4 inch PVC trap to old 1/1/2 inch metal drain line
I am cosmetically renovating an old bathroom in my home. The horizontal drain line is not roughed in far enough past my existing wall tile for me to remove an old threaded ring that used to probably seal the pipe coming out of the wall to the old horizontal sink drain/trap. What are my options for sliding a 1 1/4 inch pvc pipe into the 1 1/2 inch, and then sealing, glueing, etc. Anybody had this problem before? Connecting metal pipes to pvc?
dfg13gibson is offline   Reply With Quote
Old 08-21-2011, 04:49 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 350
Sounds like your describing the trap adapter nut. You need to remove it in order to get a seal. Carefully remove enough of the wall finish so you can get a pair of pliers on the nut.
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (08-21-2011)
Old 08-21-2011, 06:16 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
After that, you'll need a 1-1/2 x 1-1/4 slip joint washer to make up the difference between the two pipe sizes.
Journeyman Plumber
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
Main drain line lmanwarren Plumbing 1 04-06-2006 01:32 AM
