Connecting To Flanged Pipe With Missing Nut - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2013, 08:20 AM   #16
Rewards Points: 6,652
Originally Posted by CitadelBlue View Post
Or get a universal radiator hose from the auto parts store and 2 radiator clamps and MAKE an S trap. Just make sure the hose is LOOOOONG enough to accomplish the job. A good temporary/quick work around. O'reily has ALL kinds of lengths ..... http://www.oreillyauto.com/site/c/se...%28R%29&mc=GAT
Talk about thinking out of the box. I like that one better. Quick and dirty. Two hose clamps and the hose, and you are done in five minutes. Not exactly code, but it gets the job done, vs. trying to crawl under the home and then find that the nut is so corroded, or the pipe, that you do more damage, then fix the problem.
Old 07-22-2013, 09:49 AM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
Why spend as much money to hack it up as you would to make a permanent repair?
Coastal South Carolina
Old 07-22-2013, 10:24 AM   #18
It would actually be cheaper, and besides the current way it is, is hillbilly, and the OP is getting tired of emptying the bucket.
Doing the heater hose is not going to be havked up, it will fix the problem, then let the home owner deal with it later.
I would do what Citadel suggested in a situation like this.
Onboard our ships, the connection between the toilets and waste drain was nothin more than 3" heater hose material, and clamps. It is the way the Navy does it, so they will flex a little, in case the piping moves.
Old 07-22-2013, 10:32 AM   #19
Rewards Points: 2,648
Originally Posted by rjniles View Post
I would cut that J bend a few inches above the floor and use a PVC tubular drain connector and a new PVC S trap.
Sounds like a good and simple fix to me.
A universal automotive radiator hose is going to convoluted (accordion profile) and may tend to hold debris. And the hose will not have a clean out like a proper trap.
SPS-1 is offline   Reply With Quote
Old 07-22-2013, 11:25 AM   #20
Back to the drawing board. Found several supply stores in the area that carry the split nuts TheEPlumber referenced, but naturally, nobody has them in stock.
If I cut the J bend off the pipe, what fittings do I need to use to connect a new trap?
And regardless of the fittings used, what exactly do I need to use to replace the old trap if I cut off the J bend in there now? All the PVC replacement parts I've seen aren't as narrow as the J bend on the pipe currently in there, and would prevent me from making the connection to the tailpipe of the sink due to misalignment.
Thanks again for humoring all my novice questions,
Mike
M.McClish is offline   Reply With Quote
Old 07-22-2013, 11:27 AM   #21
Guess my computer is catching up... Just now seeing the ongoing debate about using the hose and clamps. It's looking like a good temporary option right now, since as pointed out, it's not my house and I'm on vacation!
-MM
Old 07-22-2013, 11:43 AM   #22
I expect RJ was thinking of one of these to make the connection.
Oops seem to be having problems with photos today.... try this link http://images.search.yahoo.com/searc...rain+connector
Old 07-22-2013, 02:05 PM   #23
A "Handy Husband"
rjniles's Avatar
Actually was thinking of this:
This is 1.5", if drain is 1.25", use 1.5 to 1.25 slip washers.
http://parksupplyofamerica.com/gprod...id=CSP58620PVC
A good hardware store or plumbing supply will carry.
The Following User Says Thank You to rjniles For This Useful Post:
TheEplumber (07-22-2013)
Need advice on rusted pipe problem silencer Plumbing 16 12-02-2012 08:59 AM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Connecting pvc and metal pipe FrFtr28 Plumbing 18 10-06-2011 07:19 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
