Connecting A Drain For A Dishwasher - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-01-2011, 10:08 AM   #1
Connecting a drain for a dishwasher
I've lived in my house for years now and desided to install an under the counter dish washer. I'm putting it in the spot where the previous owners had one. The water supply pipe is still there but in the basement where the drain pipe used to be, there is a capped off copper t. The hole in the floor for the drain tube is about 3 feet from the t. Wondering what would be the best way to connect the drain tube.
sader is offline   Reply With Quote
Old 09-01-2011, 11:24 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 556
The best way is to connect it to the sink tailpiece or disposal
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
1910NE (09-03-2011), del schisler (09-01-2011)
Old 09-02-2011, 09:44 AM   #3
Rewards Points: 3,130
What EPlumber said. If you have a disposal, there is probably a dishwasher connection on it somewhere. If you don't, the appropriate tailpiece is not expensive. Some localities require an air gap for the drain. If yours doesn't the drain should be looped as high as possible above the connection.
kenmore dishwasher cut out, won't drain, no power jess1974 Appliances 3 12-28-2010 06:45 PM
Connecting a shower drain to a toilette drain marmendariz Plumbing 0 08-25-2010 12:57 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Dishwasher don't drain all the way MattCoops Appliances 8 04-17-2007 10:07 PM
